- 3:30 AM
- Dec 11, 2025
- West Coast Mtns.
The oil pump seems to be putting out the right amount of oil, however, the adjustment screw always returns to the minimum output. I'll set the output to maximum and with just a few throttle blips the screw will be right back to minimum. I removed the oil pump from the case and there is no visible problem. The adjustment screw turns very easily and I'm guessing something is worn inside the housing--o-rings? bushing? other? I tried a few things to drive out that little pin but had to get back to firewood duty. Any tips on repairing that little adjuster? I hate to spend the money for a whole new pump since everything else looks good. When I spin the oil pump mechanism by hand nothing catches the adjuster screw so my guess is that the vibrations are turning the screw, but it's just a guess.
