Line trimmer blades
Knots
OPE Member
1:08 AM
Virginia
Does anyone know where I might find some 9 or 10 inch four cornered blades for line trimmers. I believe the arbor size is 7/8 inch.
It is to fit Shindiawa T-25, T-20 trimmers, etc..
Can’t seem to find them anywhere. Used to be everywhere.
Thank you,
Knots
7:08 AM
Pardon my ignorance, is that pre cut nylon line or flail type blades?
Picture of what You are looking for?
Knots
OPE Member
1:08 AM
Virginia
No, these are metal blades about 1/8 inch thick . 4 blades with a leading and trailing cutting edge. When one set got dull you just flipped the blade. Would easily cut material up to about 1/2 inch and would not grab a round wooden post as long as you kept the speed up. Much faster and neater in rough stuff than string.
7:08 AM
So it is a solid steel disk for brush cutting?
Do You have a part number for those You used so far?
My Dolmar ones have part numbers stamped on them.
7:08 AM
Something like this?
7:08 AM
Makita D-66020
7:08 AM
Not flippable, but I found these to be less aggressive and their heavier weight cushioned impacts.
Bill G
12:08 AM
Thank you,
Knots
Stihl but I am betting your bore is not 0.875 and it is 0.787 or 1.00
Bill G
12:08 AM
Did you find what you wanted?
7:08 AM
Curious too!
Those should be everywhere in various designs.
