- 1:31 AM
- Feb 5, 2016
- grafton wv
too much orange toad
Good lord, Id need stitches in muh head if I walked into that garage.![]()
Oh no! That's the glorious thing about having 9ft side walls. Well unless your 7'6". I'm about 5'10" is and have all I can do to get them up on the shelf.
I was looking at the proximity of the little step ladder (which I would imagine would be in the 5' range folded up) and the shelf. Which made me think 8' walls. Looks like the shelf is 15-16'' from ceiling, which would put it down 6'6'' range.
Having the 9' walls changes everything in the pic..![]()
Isnt a 200t a out board clutch ?
Pretty sure it's an outboard
Being happy with what you bought is what its about i feel , Your the one who is cutting with it after all ...They free up a bit with some tanks through them.I was in the market for a limbing saw as well. My previous saw, a PP220 42 cc model had served me well over the past 16 years but one of the bar studs finally broke loose so it was time for a replacement. After a lot of reading, I decided on the ps421 Dolmar, as price was a consideration. I like the fact that it uses 3/8 lp and is the same as my PP220 so my spare loops aren't wasted. I was able to take advantage of the fact that Makita is dropping the Dolmar name here and my local dealer has all Dolmar's on "clearance". Got this one for $289 and they threw in a case (I am a big fan of cases which keep my saws cleaner and protects them when not in use). People talk about the weight but according to my scale, the 421 is 1/2 lb. lighter then the saw it is replacing when ready to cut and has more power, so I'm happy.
If it was the rear handle version it would of course be suitable for limbing trees with tiny branches, but imo it is too small for a more general limbing saw. I have a 339xp that I use where everything is tiny, usually thinning work.Yes. Out board. I always get them mixed up...one sux and the other works fine for me.
What it really is is a PITA..
Seriously a 200t is not a limbing saw because it's below 50cc ?
sure they are great limbing saws if they have rear handle, I know one lad who delivered truck load after truck load with spruce just using one saw, MS 200 rear handle.Seriously a 200t is not a limbing saw because it's below 50cc ?
Ya hard wood ,firewood collect here so if I understand you correctly ( at least how I will present it to my wife)Back in the 1990's i spent 6 months on line thinning spruce plantation work that produced fence making wood. All the trees were planted at the same time so were more or less a uniform size of about 8-9 inch /200,225mm. The job was to work from one side to the other of the plantation taking out a row and moving on past 3 more to take the 4 th row . This opened out the growth over the years and more lines were taken to eventually leave bigger timber for milling. My tool of choice was the Husq 242 xp on a 15 in bar....thats what it was best at doing .
Softwood work where you are in lines of similar size timber is likely going to be about a single saw for the job, but you get into stands of hardwood that give you a lot of top to process for firewood with less snedding (de branching a tree trunk up its length ) but a larger trunk to deal with... thats where the 2 saw policy comes into play more IMO. I will spend much more time in one place on a mature hardwood tree of size so will take more gear to the site. Thats why i feel there could be a difference of saw choice in smaller softwood work compared to bigger softwood and hardwood harvesting /firewood. The more good saws of.. ALL.. cc's that are made to chose from the better ..in my humble opinion.
You very well may have the wit to convince your good lady of the need for MANY tools for the job SirYa hard wood ,firewood collect here so if I understand you correctly ( at least how I will present it to my wife)
I need more GEAR!
Realistically I very seldom ever go out cutting and take just one saw. I could see if all you where doing is just felling a tree and knocking the limbs off only needing one saw. That is where a good 50 cc saw would make a lot of sense.
