Ks 42mm cylinder identification
Nc grease monkey
12:44 PM
Boone, nc
Anyone have any info on this cylinder? 42mm bore
Was in a box of 026 parts that my brother gave me
Nc grease monkey
12:44 PM
Boone, nc
IMG_1589.JPG By brother scuffed the port up a little but you can see he stopped well short of messing with port timing, there's not a bevel I can see to help the ringsIMG_1611.JPG
Nc grease monkey
12:44 PM
Boone, nc
Hiw can I determine if it's for an 024 or an 024 super? If I've researched correctly they have 2mm difference in stroke.
Nc grease monkey
12:44 PM
Boone, nc
I'm gonna go with being a super, from base to squish band it's the same height as a 44mm 026, 62mm
Chainsaw Jim
Con Artist LLC
9:44 AM
Springfield Oregon
The combustion chamber looks a little bit different, unless it's just the camera angle. I think it's the camera angle and carbon throwing me off.
Cracker Boy
Fl cracker
12:44 PM
Florida
If im correct on this its been a while.
On an 024s they were 026 cranks with 42 mm cylinders. You can put a 026 44mm and 44.7 jug and slug. But i do know for a fact you can not put a 026 jug and slug on a 024 due to shorter stroke There was also an open port 42 mm cylinder as well
Nc grease monkey
12:44 PM
Boone, nc
I'm guessing the prominent "S" is for super. And it looks to me like the combustion chamber you have could be a little bit smaller.
Do 024 supers and 026 share the same crankcase?
12:44 PM
Yup. Like Jimbo said, 42mm 024 Super Jug.
Cranks cases nearly the same. The 024 usually front chain tensioner and one bar stud with a stud eliminator in the other hole. Not so for the o26 case.
You can cut the two top rear fins off, and bolt a 44mm 026 P&C on it.
