Kohler 3000 series 6.5 on log splitter
davidwyby
Rural desert logging
7:07 AM
Extreme Southeast CA
Went thru the carb quick once and cleaned the jet because it wouldn’t run, runs but surges. Buddy says it has always kinda surged.
Should I look into the carb more thoroughly or look at the governor?
Steve
Excellence!
9:07 AM
The low speed jet clogs very easy causing it to surge. It's the plastic piece that is held into the carb with the head of the idle stop screw. I usually have to poke the varnish out with a strand of copper wire and then spray with carb clean. Also if the o-rimgs on the low jet leak air you will have the same effect.
davidwyby
7:07 AM
Ok I cleaned the heck out of the carb short of soaking in carb dip or ultrasonic. I should get one of those...
Anyway, cleaner, wires, air through all the jets n stuff. Idles now but if I bring the throttle lever up, when it gets about half way (too far, out of adjustment?), I think it brings the governor into play and it goes wild. Owner says it has always surged....
I have 3/4 of a mind to eliminate the governor and I will if I can’t figure out how to fix/adjust.
off to giggle it...
davidwyby
7:07 AM
Took the tank off so I could see the linkage. I think the carb still isn’t right. Runs full throttle or idle but stalls or runs like poo in between, I think that is messing with the gov.
chiselbit
7:07 AM
Norcal
Hey David, I’m watching your video on my phone so I can’t see real good but is that something arcing in the top left of screen?
Larry B
10:07 AM
SW ohio
You have a carb issue. Any time the engine "bounces" on the governor and surging it means you have a fuel delivery problem. I would give it a good cleaning in an ultrasonic cleaner. Sounds like the high speed circuit is not working. Either that or not getting enough fuel flow into the carb from the tank
davidwyby
7:07 AM
No, I don’t think so.
I started looking for a carb online and noticed something. Duh.:rolleyes:
I think this is the problem.
davidwyby
7:07 AM
4EBC5925-1EE2-4D71-8417-2C8E078934E9.jpeg Someone twisted off what I assume was the idle mixture screw. It was all covered with crud and I didn’t pay enough attention .
Barfly
3:07 AM
At a bar near you
View attachment 274225 Someone twisted off what I assume was the idle mixture screw. It was all covered with crud and I didn’t pay enough attention .
Theyre broken off in the factory to meet emission standards.dremil a slot into it to remove.its probably locktited in there just to piss you off.
