Kohler 3000 series 6.5 on log splitter
davidwyby
Rural desert logging
12:17 PM
Extreme Southeast CA
Went thru the carb quick once and cleaned the jet because it wouldn’t run, runs but surges. Buddy says it has always kinda surged.
Should I look into the carb more thoroughly or look at the governor?
Steve
Excellence!
2:17 PM
The low speed jet clogs very easy causing it to surge. It's the plastic piece that is held into the carb with the head of the idle stop screw. I usually have to poke the varnish out with a strand of copper wire and then spray with carb clean. Also if the o-rimgs on the low jet leak air you will have the same effect.
davidwyby
12:17 PM
Ok I cleaned the heck out of the carb short of soaking in carb dip or ultrasonic. I should get one of those...
Anyway, cleaner, wires, air through all the jets n stuff. Idles now but if I bring the throttle lever up, when it gets about half way (too far, out of adjustment?), I think it brings the governor into play and it goes wild. Owner says it has always surged....
I have 3/4 of a mind to eliminate the governor and I will if I can’t figure out how to fix/adjust.
off to giggle it...
davidwyby
12:17 PM
Took the tank off so I could see the linkage. I think the carb still isn’t right. Runs full throttle or idle but stalls or runs like poo in between, I think that is messing with the gov.
chiselbit
12:17 PM
Norcal
Hey David, I’m watching your video on my phone so I can’t see real good but is that something arcing in the top left of screen?
Larry B
3:17 PM
SW ohio
You have a carb issue. Any time the engine "bounces" on the governor and surging it means you have a fuel delivery problem. I would give it a good cleaning in an ultrasonic cleaner. Sounds like the high speed circuit is not working. Either that or not getting enough fuel flow into the carb from the tank
davidwyby
12:17 PM
No, I don’t think so.
I started looking for a carb online and noticed something. Duh.:rolleyes:
I think this is the problem.
davidwyby
12:17 PM
4EBC5925-1EE2-4D71-8417-2C8E078934E9.jpeg Someone twisted off what I assume was the idle mixture screw. It was all covered with crud and I didn’t pay enough attention .
Barfly
9:17 AM
At a bar near you
View attachment 274225 Someone twisted off what I assume was the idle mixture screw. It was all covered with crud and I didn’t pay enough attention .
Theyre broken off in the factory to meet emission standards.dremil a slot into it to remove.its probably locktited in there just to piss you off.
