Just say no to AM wrist pin bearings
jmssaws
Banneded
3:30 PM
I've never used one.
I used a few when I was using a 288 piston in a 066,2 of them failed and I'm not the only one that happened to,that is the only time I've ever used one and the last time.
On a side note the 2 I had fail are the exact kind and type I'm holding in my hand above.
Lone Wolf
4:30 PM
Nj
I ran the snot out of that 066 for a short period of time.
I almost never even caught it before I put the cylinder back on.
Needless to say, I found a donor crank.
It had to leave some marks.
beaglebriar
The Peanut Gallery
4:30 PM
Warren Center, PA
The Meteor I got from HLS came with one and the one I got from Dave didn't. But I will clarify that when I ordered the one from HLS it showed up as a line item like I ordered it just with no price next to it. And I have no idea what brand it is ether.
The meteor is just got from them included a cross wp bearing. I already had an oem bearing so it didn't get used.
jmssaws
Banneded
3:30 PM
I took a 660 out of the box new that I could not get to run right and finally found the flywheel side seal had no spring from the factory.
Only leaked at high rpm.
Weird things happen sometimes
3:30 PM
Oh for sure when I get out side and take a pic side by side Iam keeping the oem or I'll drive 20 miles to get a new one
Rob Stafari
4:30 PM
Cincinnasti
It sounds like everybody's anti aftermarket wrist pin bearings, what about the pins themselves?
junkman
Crush it
1:30 PM
pacific northwest
I use a metric chit ton of AM seals.
Never a single issue.
That would be more than an sae ton
met·ric ton
ˈmetrik ˈtən/
noun
  1. a unit of weight equal to 1,000 kilograms (2,205 lb).
  2. Reg ton is 2000 lbs
Only the Junkman would know stupid stuff like this .dot dot dot .
stihl saws
You can always justify another saw.
4:30 PM
Virginia
Every aftermarket pin I've seen seems thicker/heavier than oem, on Stihls anyways. I just can't see how adding weight to the end of a rod that's moving at 13,000rpm is a good thing.
I've never seen an a/m pin bearing I would trust.
BuckthornBonnie
4:30 PM
Penn Yan, NY
Hlsupply and Weedeaterman include the needle bearing for some pistons. They're decent AM. I've used a few but am going to go back to OEM for future builds.
jmssaws
Banneded
3:30 PM
I use a oem stihl pin in everything I can.
There much lighter
Backtroller
3:30 PM
Land of Badgers
Is there a reason the meteor pin is shorter than the Stihl? I've noticed this on my 026, 024 and if I recall correctly, my 346. Being a little shorter does leave some side to side "slop." Does that matter?
I have used the OEM ones per the Docs recommendation on all the above saws.
jmssaws
Banneded
3:30 PM
I doubt under a load the pin would wonder.
jacob j.
Only the weird
1:30 PM
Coastal Oregon
It's best not to leave the wrist pin any room to slide back and forth. I use OEM pins on the Meteor pistons, even if I have to use a Husqvarna pin in a piston meant for a Stihl application or vice versa.
