- 10:27 AM
- Dec 3, 2015
- Banner Springs Tennessee
I've never used one.
I used a few when I was using a 288 piston in a 066,2 of them failed and I'm not the only one that happened to,that is the only time I've ever used one and the last time.I've never used one.
It had to leave some marks.I ran the snot out of that 066 for a short period of time.
I almost never even caught it before I put the cylinder back on.
Needless to say, I found a donor crank.
It was never there to begin with Steve.It had to leave some marks.
The meteor is just got from them included a cross wp bearing. I already had an oem bearing so it didn't get used.The Meteor I got from HLS came with one and the one I got from Dave didn't. But I will clarify that when I ordered the one from HLS it showed up as a line item like I ordered it just with no price next to it. And I have no idea what brand it is ether.
I don't even like using AM seals
The seal material just feels "different".I use a metric chit ton of AM seals.
Never a single issue.
That would be more than an sae tonI use a metric chit ton of AM seals.
Every aftermarket pin I've seen seems thicker/heavier than oem, on Stihls anyways. I just can't see how adding weight to the end of a rod that's moving at 13,000rpm is a good thing.It sounds like everybody's anti aftermarket wrist pin bearings, what about the pins themselves?
Hlsupply and Weedeaterman include the needle bearing for some pistons. They're decent AM. I've used a few but am going to go back to OEM for future builds.The meteor is just got from them included a cross wp bearing. I already had an oem bearing so it didn't get used.
I use a oem stihl pin in everything I can.Every aftermarket pin I've seen seems thicker/heavier than oem, on Stihls anyways. I just can't see how adding weight to the end of a rod that's moving at 13,000rpm is a good thing.
I've never seen an a/m pin bearing I would trust.
Is there a reason the meteor pin is shorter than the Stihl? I've noticed this on my 026, 024 and if I recall correctly, my 346. Being a little shorter does leave some side to side "slop." Does that matter?
I have used the OEM ones per the Docs recommendation on all the above saws.
