Jazzlesaurus
- 12:15 AM
- Aug 12, 2025
- Western MA
Are stoves fair game to chat about here?
I've got a Jotul F3CB I've had installed for the last 2 years and it's been a great stove for our house and family. We went from 2.5 tanks of oil to less than 1/4, while burning ~3 cord.
When I got the stove it was in rough shape, I fully broke it down, replaced all the hardware and gaskets, the broken glass, the melted through grate on the bottom, and it's been cooking away since, with a few minor adjustments.
One thing that happens occasionally is roughly every 1.5 months the glass slips a cm or so and off the fire rope, causing an air leak.
The screws do loosen just a little bit, but I noticed on the hinge side there's a bit of casting that the glass corner can rest on to keep it from slipping. On the handle side, there's a spot that has a bit of extra metal with an indent, it looks like it could be or was maybe intended to be drilled and tapped, then a small block of metal could be bolted in as another edge for the glass to rest on should it slip again.
Has anyone experienced this, or attempted a fix like this? I don't want to crack the door of the stove if I'm putting hardware where it doesn't belong, but it seems like a nice improvement for the stove.
