JONSERED Jonsereds
lehman live edge slab
Live Action
12:56 AM
Mn
So the 625,630 and 670 all the same family of saws with different top end? Just looking at Parts and lots of listings for Parts saying they fit all. Of course it was ebay.
12:56 AM
Kind of.
The 625 and 670 have a Separate impulse line that runs the carb. And use an intake boot. The 630 has the impulse going through the intake block like a 2 series husky. And I found out recently a 630 air filter cover will not fit on a 670. There was some interference at the spark plug.
12:56 AM
Can you post any pics?
Live Action
12:56 AM
Mn
I will later I honestly haven’t seen it, guy dropped it in my truck at work. I’ll see it soon when I pull it out to put in the garage. He said the top plastic cover on back handle is busted and needs maybe few other things to go with the piston and rings. But I don’t have any johnsred saws. Just figured price was right to add one to the collection. Only other one I had was a 2036 and that isn’t even a johnsred just a Poulan in red and black plastic.
12:56 AM
Cool.
Live Action
12:56 AM
Mn
C8A4C0E9-EB63-4B39-A18E-319488537107.jpeg C48B6BF5-E9B4-423F-9E81-24395BFBBC95.jpeg
Busted rear handle, haven’t looked through exhaust yet but if no scoring I don’t think top end is bad. More likely ignition and if that’s it I’ll get to see if parts are hard to get or not I guess.
WKEND LUMBERJAK
12:56 AM
West of Kansas City
12:56 AM
Live Action
12:56 AM
Mn
Yeah probably look little closer at it tomorrow. One or two piece coil and cylinder ect. I’m going to guess 2 piece for coil but just a guess. Only says 625 on it not series 2 or anything. Suppose I need a new flywheel if it has a 2 piece and want to go to one.
NCFarmboy
1:56 AM
Hayesville, NC
625 has 2 pc. coil. The module is going bad= no spark hot. It's the one close to the oil tank the other one rarely goes bad (the one w/spark plug wire). One pc. coil will not mount in 2 pc. crankcase.
Shep
Live Action
12:56 AM
Mn
So find a used two piece ignition and take a chance if it’s good? Anyway to use a aftermarket ignition like a nova 2? Or find Parts saw with one piece ignition and combine them to make one good one.
Live Action
12:56 AM
Mn
Will this one Work? I know it doesn’t say jonsred on it but people on eBay claim the two part ignition they’re selling works on a 625 and the 61 husqvarna.
Live Action
12:56 AM
Mn
Good looks like I’ll be order one, and finding a tank assembly plus the throttle rod between carb and trigger.
