- 3:53 AM
- Jan 3, 2016
- West of Kansas City
I believe just used and some NOS show up on eBay. Alot of P85 parts interchange.
Jonsereds 1020 what are your thoughts on this saw are they very collectable and worth there money
Thanks
Basically not, but most of them likely can be found.I got chance of one are parts still available
Nice series of saws. Not overly fast but they are well built, pull well and are fairly smooth from my experience with the R440 and P100. Some say they are underpowered given their displacement when compared with competitors from the same era. The 1020 is the same as a P100 Super.
I would say the Jonsereds are by far the rarest. Would be worth a few bills to someone if in sound cosmetic and working condition.
It has ...balls .. is how i would describe the performance. Me likey !I bet it does run good.
Its about a lb more than my 262 (both on 20") but with the thinner hoop handle it feels different. I will drop it down to a 15" and give it a go on the ash sticks that will be winched out soon. Thinning out timber so most is 10-14 in diameter and a reducing cut works fine on 20" timber anyhow with a 15 " bar.The 630 is heavier than the new 60cc saws, but I believe you will enjoy using it.
30 in diam timber ..even green takes a bit of grunt for sure. I would like a few more JR's if i can find them ...a 630 supper 11 or the husq 372 equivalent Jonsered would be achievable i think . JR have pulled out of the UK i believe as a stand alone brand so new saws are no longer really available and second hand there fairly rare.For about 10 years, my big saw was a 625 which was a little lower rpm and hp than the 630. Since I didn't have the internet then, I cut up some 30" wood with that saw. Now thanks to the internet I realize I need at least a 90 cc saw for that size wood. Later I got a used 670 which is definitely a nice step up in power from the 625.
I would say 26 yrs isn't a bad service record before major meltdown .For many years my only saw was a 621 with 16" and 24" bars. I did normally remember to change the sprocket from 8 to 7 T when putting on the longer bar. That particular saw was run hard for 26 years before I finally failed the PTO side bearing and spit a few balls up through the transfers.
Mark
Just picked up this 801 and this 90. I will rebuild the carb on the 801 and see how it runs soon! The 90 went down sometime in the 80's, so I doubt it has much hope, but I will look into it anyway. Hopefully the cylinder will be salvageable. If the they were both perfect, which would be the preferred model to have?
