Jonsered limiters
cuinrearview
Handy dood
11:31 AM
Dowling, MI
The red and white caps over the screws have wings on them to physically limit the adjustability. Remove the carb from the saw(hit the area with compressed air first) and either pull the entire cap off of each screw with needle nose pliers or cut the little wings off of the caps with a razor or dikes.
Stevetheboatguy
10:31 AM
Nw IL
I was hoping it could be done on the saw
It can be done on the saw.
Personally I would clean both saws real well and update the intake clamps while you are tinkering. Looks like both your saws still have the original plastic. Probably be fine but ehh it's cheap and easy preventive maintenance. Save you from a air leak burn down.
Steven
11:31 AM
Steven
+1
beaglebriar
The Peanut Gallery
11:31 AM
Warren Center, PA
View attachment 215036 Is this what the metal intake clamp looks like
Yes but you can use a 385/390 intake clamp over the existing plastic clamp. Just have to do a little Dremel work. They're about $5. I go through a lot of them, ordered more this morning.
cuinrearview
Handy dood
11:31 AM
Dowling, MI
I snap all of both tag ends off of the plastic clamp and slip a 372 clamp under it. The 385/90 clamp over top is a little neater just make sure to leave a gap in the broken off plastic clamp so it can snug up.
