t4driller
Daddy Day Care
- 1:16 AM
- Feb 23, 2016
- Southwest pa
I've been working on a jonsered 820 with heated handles for the last couple weeks. So far I installed new crank, bearings/seals, av mounts, and made my own crankcase gasket. Also fixed the wiring for the heated handles. They were all chewed up and broken. I'm currently working on the cylinder. It's 52mm side fed transfers with windowed piston. I also have a 54mm 910 cylinder that's bottom fed transfer. I originally was going to put the 54mm top on it but after taking timing numbers and squish I decided to use the original 52mm p/c. Numbers of both cylinders are...
52mm w/out base gasket
Ex 105.5
Trans 125
In 72
Squish .023
54mm w/out base gasket
Ex 105
Trans 124
In 62
Squish is more then .050
I checked the pin to crown height and skirt length and they are both the same for each piston. So I'm not sure why the squish is so much. Both are 38mm stroke also. ( thanks redfin) .
I already started to port the 52mm cylinder. Widened the intake/exhaust. Raised the exhaust to 104. Lowered the intake to 75. Also did some work to the lowers. So here's where I'm at at this point. Any input is always appreciated[emoji4] [emoji4] pics of progress
Ex 105.5
Trans 125
In 72
Squish .023
Ex 105
Trans 124
In 62
