Johny 2077 piston options
Brewz
2:17 PM
Hunter Valley - Australia
Hi Folks.
I have a friend that needs a new piston for a 2077
The 2077 piston has a compression height of 22.5mm and overall height of 42.5mm
He has been told an 046/460 piston will work and when I dug the Meteor 046 piston I have here out, its compression height measures at 21.5mm but the Meteor website claims 22.5mm???
Can someone cross check my measurements please.
I get 15.5mm from crown to pin top plus half the pin at 6mm is 21.5mm in my book and 39.5mm overall height.
The other piston I was looking at was a Dolmar PS9000 piston with 22mm comp height and 44mm OAL
A gasket delete and trim 1.5mm off the skirts and it would be very close to stock provided the dual ring ends tuck in.
Can anyone recommend a piston to use?
12:17 AM
Brewz
2:17 PM
Well he just messaged me to say he tracked down a 2077 meteor piston?
Im still curious about the measurement difference in the 460 piston I have and what the Meteor website says
12:17 AM
I don't have a meteor. I have an oem I can measure.
12:17 AM
I got the same 15.5 pin to crown. 066 is 17mm. I think the 64 is the same
Cut4fun
Redneck Chainsaw Repair
12:17 AM
Ohio
Best option IMO for you is to use a 064 meteor. Just need to open the pin bosses.
The BB372 is drop in but no good aftermarket piston. Have used and worked for stock.
