oldcoot
OPE Member
- 11:44 PM
- May 7, 2023
- virginia
When I try to start mower I get a lot of rapid clicking noises coming from the solenoid. I've read several guidelines on how to test solenoid by jumping the two solenoid posts to see if engine will start. I'm confused about what the ignition should be set on when doing this.... OFF or ACCESSORY.......or do I jump the posts while at the same time turning key to START. Do I have to be seated when doing this in order to bypass safety switch?? And if I'm understanding correctly, if the engine starts when I jump the solenoid that means the solenoid is bad, but if engine fails to start then the starter is bad ?? Any help is GREATLY appreciated.
