John Deere D110 Not Starting
oldcoot
OPE Member
1:21 AM
virginia
When I try to start mower I get a lot of rapid clicking noises coming from the solenoid. I've read several guidelines on how to test solenoid by jumping the two solenoid posts to see if engine will start. I'm confused about what the ignition should be set on when doing this.... OFF or ACCESSORY.......or do I jump the posts while at the same time turning key to START. Do I have to be seated when doing this in order to bypass safety switch?? And if I'm understanding correctly, if the engine starts when I jump the solenoid that means the solenoid is bad, but if engine fails to start then the starter is bad ?? Any help is GREATLY appreciated.
Woodtroll
1:21 AM
Mtns of SW VA
Rapid clicks or chatter from the starting solenoid usually means a bad or partially discharged battery, or corroded battery terminals, in my experience, caused by the sloenoid not having enough energy to "latch" the contacts completely under load.
If you're jumping the two heavy posts, the starter (if good) will usually crank regardless of key position, but the engine will only start and run if the key is turned on. Some mowers may be wired differently, but this usually works. Don't use a good screwdriver or tool, as the arc from jumping the terminals under load (the starter) will usually burn a hunk out of the metal. Be prepared for the spark, too! But do check your battery voltage and battery terminal connections first.
Shane¹
1:21 AM
Kentucky
I would agree with @Woodtroll usually clicking is low battery. Usually if starter was bad solenoid wouldn't click rapidly starter would simply not spin and if it was the solenoid it would just click once but starter not crank also. Jumping it then would rule out if solenoid is bad internal. But you could simply check with a volt meter much easier. Battery voltage static, voltage incoming to solenoid, voltage out of solenoid when trying to crank, and voltage at starter
stretch5881
12:21 AM
Hatley, Wisconsin
I'm also going to say battery. When the battery is rested for at least 1 hour (no charger on it), it should have at least 12.3 volts. If it's below 12, it's shot.
066 redeye
5:21 PM
Tasmania,Australia.
you can also put jumper leads direct from battery to starter motor.
This will prove battery and starter bypassing solenoid.
Billc
OPE Member
12:21 AM
Gulfport Ms.
Was going to comment but the Gentleman that already commented have covered it all and should solve your problem
oldcoot
OPE Member
1:21 AM
virginia
I replaced battery and solenoid.....still only get rapid clicking. Left battery connected to mower as usual, connected jumper cable from battery positive to starter and only got sparks. Starter made no noise. Would a bad starter make the solenoid click rapidly?
SawAddictedFarmer
12:21 AM
Your going to get a lot of sparks wether it's good or not. I would take the starter off and make sure it's spinning freely and then test.
066 redeye
5:21 PM
Tasmania,Australia.
You should be able to take the plastic top off the motor and see what the bendix drive on the starter is doing.
Might be jammed/need lubing.
EFSM
12:21 AM
Extreme southern IL
No it won’t. But it should crank over with voltage fed straight to the starter. Make sure the engine turns over easily by hand by rotating the top flywheel screen.
OnlyStihl
11:21 PM
PNW
Not suggested yet. Jump start the mower with your automobile. If it starts it was the battery, which may only need a good charge. I've had a lot of battery problems lately and IMO it is the AGM batteries that are supposed to be so great, which ain't so.
oldcoot
OPE Member
1:21 AM
virginia
I'd like to reply to all who answered but I don't know how, so I'll reply to you. IT WAS the battery. The new battery I bought only had 190 CCA and the Deere calls for 300. I jumped it with the car and it started fine so I realized the new battery wasn't strong enough. Also the old battery charged up to 12.5V but the next day it was down to 11V without being used. It was 8 years old. I switched the new 190CCA battery for a 300CCA and hopefully it will start tomorrow. If it doesn't I'll be back in touch with you. Anyway thanks for helping me out with this!
