It happened on Ebay - classic customers
Definitive Dave
Piss Rev Mafia Member
3:43 AM
Central Ohio
No names and I assume this "mechanic" isn't a member here.
CUSTOMER Purchased this auction -
Husqvarna 350 Chainsaw piston kit44mm replaces 503899601 w/ ring, pin, circlips
Customer Message a couple weeks later:
hi guys
i ordered a a piston kit for a customer saw the one sent is husk 350 kit factory #hs 35044 well it is .030. to small the # of the saw is a husk 350 967 01 18-00
03.2204173 husk AB my piston is 1.770 the one i was sent is 1.740
so what up with this .please look in to it and give a answer .
(I thought he meant his piston was .03mm too small when I responded to him)
Dave Message same day:
that is within the usual tolerances for these parts, the rings actually make the seal to the cylinder
go ahead and install it and I believe it will be fine, if not, let me know and I can take care of it
thanks
Dave
Customer Message a week later:
there is no comp and it is not .003 it is .30 way to small
I will refund the piston, are you measuring in mm or inches?
pistons are specified in mm
are you saying it is 3/10 of an inch too small?
I am just trying to figure out if the wrong part got packed or if your saw isn't a 44mm model
thanks
Dave
Customer included two pictures with his Message a little later:
the piston is 37 thousands to small please take one out of the box and mike it up. the first pix is your piston @1.732 the next is mine 1.769 out of a 350 husq. #967 01 18-00 03.2264173 thanks
Customer 2nd Message a few hours after first message:
if you look at the pictures your piston and is smaller than the one I need you have it exactly backwards u sent me a 43 mmi need a44 mm read the mic. Are u a mechanic or a desk person if so please pass it on to some one that knows how to read a mic. I need a piston bige not a smaller again thanks
Dave Message the next morning:
1.731 inches is 43.96mm (44mm piston which is what you ordered and I sent you and as labeled on the box)
1.796 inches is 44.9326mm (45mm piston is not what you ordered, but it IS what you need)
YOU NEED A 45mm PISTON NOT A 44mm PISTON
YOU ORDERED THE WRONG SIZE AND SENT ME THE PICTURE TO PROVE IT!!
I can read a mic.
All chainsaws since the Mid 1970s are metric size cylinder and piston.
If you don't have a metric mic just pop your SAE measurement in google and ask for a conversion to mm.
There is more than one size of piston for the 350, which is why the measurement is included in the title line.
Searching ebay for the Husqvarna 353 piston will likely pull up more results for the piston you need.
To return the wrong piston you ordered, simply start a return in Ebay and select "wrong size, doesn't fit" as the reason and then send the piston back and we will issue a refund as per our refund policy (80%)
thanks
Dave
I spend a couple hours a day answering questions like this, usually after they have the wrong part in hand :(
angelo c
Coal Member
3:43 AM
Not Clorox safe? Send it back!
[emoji48]
Did you order the 44mm bottle of Clorox or the 45 mm bottle of Clorox ?
Because the 44mm bottle is known to jump onto DDD shirts in excessive quantities . Reverse polarity or arroaboralis(sic) effect I believe
3:43 AM
I won't mention any names but one of my 125 Macs ended up in Minnesota and that gents Dolmar ended up with me .We got it straightened out .When I called the guy his wife came on the phone.I asked about their winter .She replied in that cute little voice,not tooo badd it's been mild sooo faar,15 below for the last two weeks .I pictured this cute blonde with Viking ancestory .Chit happens some times no sense getting all bent out of shape over .
Deets066
AKA Deetsey
3:43 AM
Just bought a 038 tillotson carb. So I thought, it was labeled as a new Tilly HE 19 A, Bing design it says.
So I open the box and it's a Zama lol. I send him a message telling him he sent me a chinese Zama carb, he said he was sorry and that he only sells aftermarket parts. I tell him, it's not aftermarket, it's oem but your not selling what you have listed. And you don't even know what you are sending! He did offer a full refund but I keep the carb and he sent me a $3 refund also. So it only cost me $10
Definitive Dave
3:43 AM
Central Ohio
My MS360 top end kit ended up in some person's sleep apnea supplies in rural Ohio.
USPS is always ready to assist our Dave.
Wow I had forgotten that, good times :)
Post office is always willing to help me out with unique delivery routes :)
At least a twice a week I get messages along the lines of - I live in Alaska, why does tracking show my fuel line currently in Haiti?
