“It ain’t got enough power”
av8or3
7:36 PM
Waleska,Ga.
How many times have you heard that? I set saws up by the book and I get complaints about them not having enough power. I can’t count the saws that come in screaming, on the cusp of blowing up. I’ve decided as far as those saws go, I’ll not adjust them. But fir the ones I build I still think it’s best to stick with the specs. What say you guys?
7:36 PM
Well it's kind of hard to make a silk purse from a sow's ear they say .You get those big mystery questions on some forums that goes similar to this : "what's wrong with my saw " .How pray tell do you tell somebody why their super duper Stihl 290 won't out run an 044 . I gave up a long time ago .:)
5155
7:36 PM
pa
I'm that guy that runs his too fuel rich.
Really should get a tach.
A tree cutter commented on my 034 being rich.
I handed to him, he opened the hi a little.
Noticeable as it blips. But not so much when cutting.
That one is running real good since the top end refresh.
sledneck22
But, is the chain sharp?
6:36 PM
WI
Most people need to learn proper chain sharpening and bar dressing more than they need extra power
Exactly. Every. single. saw. that someone brings to me to "tune up" has a dull chain. The saws just scream when trying to test it in the cut if it starts. I tell people now, if I have to sharpen your chain, it'll be $20... But I do retune peoples saws after said "tune up". (usually just entails maxing out the limited hi-jet and properly tuning the low end).
7:36 PM
Any Stihl I've run is a disappointment
But I have not run the new generation computer saws 462 500i .
Did run a strong 064 once but that's about it.
12:36 AM
Exactly. Every. single. saw. that someone brings to me to "tune up" has a dull chain. The saws just scream when trying to test it in the cut if it starts. I tell people now, if I have to sharpen your chain, it'll be $20... But I do retune peoples saws after said "tune up"...
So true!
Not that I claim that I actually know what I am doing, but whatever I do works for me and I am not craving more power than what I have and use.
As a firm principle I DO NOT MESS WITH OTHER PEOPLES OPE ANYMORE.
Once You touch it the owner holds YOU responsible for any issues in its future, including the chain being dull and rocked AGAIN - like how and why, You must have sharpenned it wrong!!!
Dieselshawn
7:36 PM
Southern Ontario, canada
My ms260 was a huge disappointment when I got it back from a Stihl dealer where it was sent for a carb clean and tune up. Also needed a front muffler cover.
The saw was quieter than it used to be.
Turns out the dealer put a single hole front cover on and tuned it for that.
It sounded so weak and I hadn’t cut wood yet.
Had the cover gutted, then a logger tune it for me. Much better.
davidwyby
4:36 PM
Extreme Southeast CA
When I have that problem I send them to @Benwa or @huskihl or buy my way into a @Mastermind saw :D
@Red97 how much power difference can you see on a dyno a little fat vs. perfect vs. edge of lean? A little fat doesn’t seem to slow my ported saws down. Especially not the 6100.
Red97
7:36 PM
MI
Really just depends on the saw and the intended powerband.
98% of the time if the saw is tuned above peak power rpm 8-10k the graphs don't show any difference.
If a saw makes peak power at 9k and is tuned to 15k, it still isn't going to raise the 9k power number. Actually I have seen some lean saws lose power below the peak rpm vs rich saws.
Duane(Pa)
It's the chain...
7:36 PM
Centre County
So true!
Best Answer material right here...
Stem
Professional Cup Stacker
7:36 PM
Pennsylvania
had 2 saws dropped off over the weekend, both Husqy's (had to get my jab in lol) a 455 & 460... the 455 starts but barely idles, the 460 "has no power & cuts slow."
guy that owns the 455 tells me he let somebody borrow it, and that person used SAE 30wt instead of 2 stroke oil mixed at 32:1... the spark screen was so clogged , worst one I've ever seen. I pulled the carb, cleaned it, replaced the fuel filter & spark plug, it runs fine now.
onto the 460. checked spark plug (clean), spark screen (clean) air filter ( kinda dirty so I cleaned it) starts easy & runs fine without a B&C on. I look at the chain which had some rust on it, 2 links were semi-stuck, but literally EVERY driver is burred up so bad. So I look at the bar groove & its filled with so much pitch and dirt, oiler hole is clogged and the sprocket tip barely turns by hand.
sometimes I just shake my head.
Maintenance Chief
7:36 PM
South Carolina
Yeah Sharp chains! It's weird how people are amazed by them.
Also what Al said, home owner saws being used in a industrial/Professional setting makes me a little crazy, the pro level saws even from the 70s walk all over the cheap home owner stuff and people just can't put 2+2 together about it?
Honestly most of the time I offer to let somebody run my 088 ,Super1050a, or 394xp while I'm standing by are frightened of them, *b-wording about power tells me there improperly using the saw.
7:36 PM
Lean is only mean for a cut or two (racing). Heat kills power.
Dieselshawn
7:36 PM
Ive had that told to me too. I offered my friends and relatives to use the 660 several times.
They seem to have a hands off policy towards my saws except my little 026 and 260’s. Then cuss about how gutless their own saws are.
