Derf
- 12:09 PM
- Jan 13, 2016
- Long Island NY
There may have been some Tillotson carbs (made in Ireland) used back in the 2-series/transition to 3-series huskies, but Husqvarna hasn't used them on many saws in a long time.
The 371/372XP pre-EPA came with a Walbro HD-6B (Japan). The 372xp EPA came with a Walbro HD12B (likely what you have). The 372XP X-torq came with a Walbro RWJ-4. The advantage of the RWJ-4 is that the Venturi is larger than the HD12B and the theory is it flows more air which would match increased fuel delivery which could be better harnessed for a ported saw. [Keep in mind, on a x-torq saw, although the carb's venturi is larger, only half the area is devoted to "charge" flow (air+fuel) for the saw. There is a divider in the air filter holder (air horn) and boot to divide the air flow so half goes to the strato ports to flush out exhaust gasses with clean air (no fuel). ]
Downsides are that the RWJ4 bolt pattern is clocked from the pre-EPA 9'oclock/3'oclock to 4/10oclock on the x-torq. To get it to work you need to use the x-torq blue choke lever, the x-torq air filter holder, and x-torq boot between the carb and cylinder. The boot is rotated so the bolt holes line up.
Interestingly, the Dolmar Ps7900 (80cc saw) came with a Zama C3M carb (China). Although it's made in China, Stihl bought them. This particular model carb is the same carb that came on Husqvarna 365 specials (65cc saw), and has a smaller Venturi than the 372's HD12B. One might falsely assume that because it has a smaller carb Venturi it cannot handle the air/fuel delivery requirements of a 70cc+/ported saw. [Recall, the x-torq saw was actually only getting half the airflow of its carb, so Venturi size alone is not the b-all-end-all design spec to chase.]
@Poleman and @Terry Syd experimented with these Zama carbs because they have independent jetting passages (circuits), unlike the Walbro, which allows using needle drills to open up specific jet holes to balance/flow more fuel for a better tune for ported saws.
I have a Zama C3M on my 372XPW (75cc/ported) that was worked over by Poleman and it performs better than the stock HD12B. Faster acceleration, higher RPM in the cut, and faster cut times. I posted a video to prove it in the Chinese 372 thread.
https://r.tapatalk.com/shareLink?sh...orum.com/index.php?posts/512566/&share_type=t
Going to a 385/390XP carb is following more of the same theory behind going to the x-torq carb. Just an even larger Venturi.
