- 10:49 AM
- Dec 3, 2015
- Banner Springs Tennessee
Meh.....too much trouble. Plus, where would we put those posts?
Randy, do you remember what compression you used to go for when you ported the 362? Just curious as that seems to be about my easiest to start saw.
Here is one compression question that gets me. Can you increase cranking compression without changing squish clearance?
For discussion......
Here is one compression question that gets me. Can you increase cranking compression without changing squish clearance? Here is an example, if your filling the crankcase more from the intake, does it put more up top to compress? If you lessen intake duration and that increases crankcase compression, again you are putting more to the combustion chamber, does that make more cranking compression?
A lot of variables with different saw manufactures but here is what I don't understand, screw a gauge in the saw, first pull what does the gauge read? Does 90 psi indicate great cylinder fill? Does 60 psi mean your leaving something on the table? I only base this from my experiences, and it's just one of those things that is foggy in my mind.
I might have a set split if you don't mike.I have cases but they need split unless you're talking 365 poulan
So here are a couple benefits to this style550xp has the nicest factory combustion chamber I've seen, IMO. Its factory machined. Small chatter marks can be seen. Tho I'm no a fan of the small spark plug. My 50 screnches don't fit.
Charge trapped in the squish (end gasses) are largely Unburned. They subtract from the fill of the cylinder. The charge available to do work.
The wide shallow combustion chamber is easier to completely clean out during scavenging. Imagine the charge hoes up the back wall and swoops through the chamber before hitting the exhaust. If the combustion chamber was smaller in diameter but deeper it would not be as easily cleaned out.
On the flip side we know the benefits of higher squish velocity.
We have no way to measure dynamic (would need to be measured at WOT), but the more air / fuel that comes in the cylinder, the higher it will be. So a good porting job (or even deleting the base gasket to increase intake duration) should improve dynamic compression.
Just like a SC or Turbo engine need lower compression ratios than a naturally aspirated engine.
