Fullkip
Timber Faller/Saw Porter/Hunting Guide
- 12:27 AM
- Apr 1, 2016
- Douglas county Oregon
Just looking for tips from the Husky pros. Heres where I'm at: saw is a 357 xp . I updated to the steel clamp all OEM new intake track. I have done this before on several 346/357 without air leak issues.
This time I used Hondabond for the first time. The leak is just forward of the inpulse hose. It's hard to pump it up to 5psi, so bad leak.... I let it set up overnight. What a pain on a glue job no base gasket. I have it apart for the third time..
I let the glue cure for a couple minutes before putting together per tube instructions. I have had mixed results dry [no glue]. At first it leaked bad under the clamp , had to use a 385 clamp. The snap clamp leaked bad.
So what is the best glue to bond rubber and aluminum and rubber to rubber?? Does anyone sand the collar so it glues better? Tips for installing dry?
Thanks for any tips... gotta get to cleaning the glue off again...
Fullskip
Fullskip
