I want a roof over my mill
paragonbuilder
10:16 PM
Norwich, CT
Here are the logs ready to receive rafters and floor joists.
exSW
'Cause Thomas is a poopyhead
10:16 PM
United States
How do the logs bolt? I see the recep holes in the third course . Premade or do you put them in?
paragonbuilder
10:16 PM
Norwich, CT
Dan, will the majority of the receptacles be in the baseboard, or will they be mortised into the wall?
If you look close they are there. We use a router on the bench before installing the logs.
exSW
10:16 PM
United States
No, you have to come up thru the floor.......drill each log as you go up.
I built a Heritage years ago. They pre drilled for the thru bolt system. After I built that one they started predrilling everything on center for the the bolts and electrical chases.
paragonbuilder
10:16 PM
Norwich, CT
Yeah, I measure and drill on the horses with a 1" auger bit. Than I chase it with an 1-1/8" holesaw because the holes tend to be stringy with the pine being wet. The Holesaw cleans it up. Than every 5 or 6 courses I chase it with a 4' flex auger but to lose some of the steps from being off a little.
I use to drill each log after installing but they fill up with chips and it would take me a couple days with a snake trying to get all the holes cleaned out. Especially the ones that go from bottom to the top.
srcarr52
10:16 PM
Iowa City
Here is a better picture.
I love those old work boxes. It's much nicer to attach to a stud than use the finger type on the drywall.
paragonbuilder
10:16 PM
Norwich, CT
I just wish they made them in a narrower depth. I'd like to leave a little more meat behind them for insulation purposes. But I'm not complaining when I'm tucking joints in the boxes...
