Black Dog Chainsaw
Mak-Crazy
- 2:18 AM
- Jan 8, 2016
- Indianola, IA
So I know I have seen lots of build threads pop up on here so I thought I would contribute one. I don't know how to do the port timing numbers yet, but will do all I can. Pics first...
Casting looks great.
Piston looks really good too.
Nice arch to the exhaust and pretty smooth out of the box.
Upper transfers have some pretty heavy beveling. Not bad but probably a hair more than what's needed. Same for intake and exhaust. Better to have it over sharp edges.
Lowers look smooth. Good as is but a little foredom work would improve them.
Cylinder roof looks flat with decent combustion chamber.
I always use cabers. The boxes look the same but the rings are different. I have done more than a couple hyway kits with the rings in the kits. Initial compression is good on both but the hyway kits have come back more often than not with 20-40lbs less compression and finicky starting problems. Fixed with fresh cabers and not returning.
I will check back in with squish numbers and whether or not to delete the base gasket. This will be simple swap out, no porting or fancy pants stuff. Just good rings and possible gasket delete.
