blacksmith
- 2:21 AM
- Dec 14, 2017
- central PA
Beautiful saw Dan! That thing is a screamer, I'd be grinning for ear to ear myself!
My Doc Al @drf256 , souped up, MOFO, super light saber, lazer blade of an 044/046 hybrid arrived yesterday.
I've been grinning from ear to ear ever since. What a special saw this thing is. Can't thank Al enough for taking this project on.
Nice!
Now you need to put it down and finish the Mo-Olive-Fo 026.
Pitty the poor trees growing anywhere near that fleet...Yikes!Got a tank through her today and she rips. Running 8 pin with 28" light bar and RS chain full comp.
Ate the big maple but nice. She was 4 cycling here and there in the cut so I may turn her up a little more once more break in time. Love it... Didn't get a chance to tach it but probably mid 14 or so is my guess. She will want to turn more
Saw is a light weight powerhouse. One of the smoothest stihls I've run. I think Als theory of the 272 slug being lighter and less vibes is confirmed. I've run mustang Mike's CFB hybrid and this saw is likely smoother. We can have a lot of fun comparing at the upcoming GTGs.
Here's a pic of her hanging out with her husky friends the twin 372 xtorqs, the 385 hacked up saw, and the Mason muffler modded 262 creampuff that came from CT shore Craig's list find. Great lineup. The twin 346s are in the shed behind these saws. Also she took a ride on the bucket truck home today with her husky friends.
Awesome saw. A huge thank you to Al for building it for me! I'm psyched.
Sent from my XT1585 using Tapatalk
Tip quality productsNot yet Mike. And hopefully you won't get any issues. But when you do, they will be catastrophic. The chinese just cut costs at every corner. Metal in the bearings are not good steel and not heat treated the same as more expensive bearings.
The lists just go on and on. They build and make disposable products. Simple as that.
Yup -- that is the thought. The husky 272 piston made by meteor is lighter than a 460 stihl oem piston. Al had to trim to fit. Saw felt super smooth today.I wonder if the smoothness of it has to do with the lighter piston. Back when I was building 046/066s, I could lessen the vibration (or at least change the "frequency" of the vibration) by changing the weight of the piston; which is a big help when a person has a touch of arthritis.
True, but the factory did some balancing already.Closer to be balanced. If you want it smooth as possible just balance your rotating assembly. Not sure of the power gain, but it should result in the least amount of vibes
Has anyone made a reverse hybrid?
I'm just thinking how well a 365 husky runs and stuff.
