Husqvarna o ring substitutions
BuckthornBonnie
4:56 AM
Penn Yan, NY
angelo c
Coal Member
4:56 AM
Mattyo
Youtube speciawist
4:56 AM
Farmington, CT
They mentioned stuff but didn't mention dimensions...I'll take a closer look when I can. I think the viton thing is interesting in that it's not good in the cold. For a saw...that might be bad. Interesting.
Mattyo
Youtube speciawist
4:56 AM
Farmington, CT
I had a closer look at the AS thread, it DOES mention dimensions of the stihl o ring for the 044...because its right on the BAG
https://www.ebay.com/p/825000079?ii...RW_Q8pukJm4XykXtEwkb3-pQvNamzFLBoCG90QAvD_BwE
12x1.5mm o ring. mcmaster has it in viton https://www.mcmaster.com/9263k296
$10.10 plus ship for 25 o rings. from ebay around $8 for one.
the AS thread also mentions grease as being effective enough to not require the o ring... an idea @tree monkey had mentioned that to me years back
the husky one is MUCH thinner though, about .025" ... and about 15mm ID... I just have not found a source of such a piece yet
3:56 AM
Did you check with the oring store I linked?
Mattyo
Youtube speciawist
4:56 AM
Farmington, CT
i already have some stuff on order from them, but they quote the same charts as a lot of other o ring places, ... the thinnest ring they have is .040" cross section, so if I'm looking for an o ring for the 372, it needs to be about .025" cross section and they dont' have it. if I get desperate i'll start calling around and they will be a place to call for sure.
3:56 AM
I found the orings that fit the Stihl high and low needles there. Its amazing how often I've needed to replace those over the years.
Good luck in your search.
Mattyo
Youtube speciawist
4:56 AM
Farmington, CT
You can make orings too. We make them for high pressure caustic pumps etc and they hold up so gas wouldnt be a problem View attachment 232247View attachment 232248
yeah I just don't trust myself to make the correct o rings in this particular application. but this has been suggested... thanks
ftr, i never planned on working on as many saws as I have... especially the 2 series stuff. them damn xrings have provided much annoyence to me because dealers want $5 each for those... which is a factor of 100x markup. ...and I always seem to be short of them. I can use a piece of fuel line, but its just too jury rigged for me. best to have the right part, just hate to pay 100x markup
Pincher
3:56 AM
sw corner of twin cities mn
Part of the expense comes with the excellent packaging. Not only is it well labled, it is also contained in a nice ziplock bag which prevents it from being damaged by loose pins....
Pincher
3:56 AM
It was free shipping. I had sticker shock when pricing. To order a pkg and shipping from mcmaster would have been more. Dont plan on doing more any time soon.
Lightning Performance
4:56 AM
East of Philly
Me neither so I'll get my O rings from you :D
Looking at the 288 so far.
Fuel cap O rings for four big saws please :D
I try to have my order in by next week :p
Don't sweat the X bushing... can stack O rings for my saws :D... you can include some of those too :cool:. I cut many square rings for stuffs from quality fuel line or punched out from flat stock.
I have piles of them there Buna O Rings to look through tonight. Found three containers so far. Air shock lines or air ride lines have small O rings for the tiny bits. They also work to dampen screw movements as Randall mentioned.
KennyWinCT
Kens Small Engines
4:56 AM
Trumbull, Connecticut
Ken....u now remind me I gotta look up fuel cap orings. ...jeeprrs.
I use Brown Viton O-rings from a Harbor Freight Kit for fuel caps. So far so good. They tend to flatten out over time. The poulan lower priced saws are the worse for leaking/tight gas caps
