Husqvarna coil testing
lannie
New OPE Member
10:17 AM
new iberia
Does anyone have the specs for a Husqvarna 435 coil, looking for primary and secondary ohms specs ranges
I have fresh fuel, great compression, new carb, spark, not flooded, exhaust clear, new air filter, new spark plug, and it will not start. I read maybe the spark could be weak? hum, next is to test the coil and ignition in more detail assume
Anyone have the spes?
David
Duce
11:17 AM
Roscommon, MI
primary 0.4-2 secondary 6-10 is my guess. Is you air gap correct 0.3mm? With a firm pull and getting a nice spark, is what I look for.
lannie
New OPE Member
10:17 AM
new iberia
im getting like 1600 ohms on the secondary. I get a spark. With a weak spark it should still pop, correct? I tried pouring a few drops of gas directly into the spark plug, just to see if it was not getting gas. Still no pop. I have replaced near everything new on the chainsaw. Its driving me crazy that it will not start. I can get it to pop if I use starter fluid. Since started fluid is mostly vapor, would that mean that my spark is way too weak to ignite gas?
lannie
New OPE Member
10:17 AM
new iberia
Duce
11:17 AM
Roscommon, MI
If I am understanding you correctly, sounds like you have a fuel delivery problem. Spark plug wet after several pulls? Pinched fuel line? Fuel tank vent open? Have you tried a different spark plug? Air gap correct? Check simple stuff first.
lannie
New OPE Member
10:17 AM
new iberia
NO, I'm not getting a wet plug, I have a full tank of fresh gas, new carb, (the old carb does the same thing, the saw in in like new condition btw, new plug, new fuel lines, new air filter, new fuel filter, new primer bulb, and I check and triple checked the fuel lines, when I prime, I get fuel cycling through the carg and back to the tank. I have a very good compression, I check the piston for scaring, look brand new, whih the saw has very little hours on it, maybe 8 hours max, but it is about 5 years old. I use the saw about two weeks ago, It would run great until it warms up, then if I stop it I could not start it until it was completely cold, so I decided to try a new carb.
Its strange, if I choke it, it appears to hydrolock and appears to be flooded, but I take off the plug and the top of the piston is dry and so is the plug.
So I tired starter fluid and it pops and run about 2-3 second until it burns out the starter fluid.
I work on my owe cars, trucks, etc. But this chain saw is whipping me
I have near everything new etc the coil.
But I cannot figure out why the plug is not wet.
But if I pout a few drops of gas on top the piston, it will NOT pop, but it will with starter fluid which makes me thing it a weak spark.
lannie
New OPE Member
10:17 AM
new iberia
I have money and I can bring it to the shop. I have another chainsaw. I really do not have to fix it. It's a challenge for me. I want to fix it myself. Its driving me crazy that it will not start.
mbret2004
11:17 AM
NEK, Vermont
How old is the gas? Non-e if you can get it is best. Two to three weeks with ethanol fuel and its crap.
mbret2004
11:17 AM
NEK, Vermont
Sorry, you have fresh gas. Something between the carb and tank seems odd for the info you posted. The engine pops on starter fluid suggests a fuel delivery issue. Is the filter clogged? Use of eight hours in five years suggests brittle diaphragm/ fuel pump in the carb. Did it have fuel in it when stored? I would take apart the OEM carb and look at the diaphragm, screen, and needle and seat. I don't know where the carb came from, but always use OEM. Cheap Chinese carbs suck.
