Husqvarna clutch remover
tickbitintn
10:07 AM
middle tn
I know that on the 350's the case bolts loosen and cause air leaks.
Those would have to loosen a long way for that to fall out I would think.
One wouldn't think it would run long enough to cause all that damage.... But there it is!
Lol
DELETED (Struggle)
10:07 AM
iowa
There was a small pile of mangled metal in the bottom. It must have been the plate chewed in two pieces
BuckthornBonnie
11:07 AM
Penn Yan, NY
Yep, that’s how they go. Excessive heat and bad oil is my guess, but who knows. I had one come in with what I thought was welding splatter on the piston and spark plug (scored intake side)... nope, it ate that shim/shield/cap just like yours.
DELETED (Struggle)
10:07 AM
iowa
It definitely is not a well cared for saw. I think the cylinder could possibly be saved as it is butter smooth on top and a rough edge on the bottom of the intake side and could be cleaned up.
Partner
5:07 PM
Poland
I wanted to give you my clutch puller ;-)
