Husqvarna 562 XP Mark2
J.Noss
1:23 PM
Duncannon Pa
Has anybody had a chance to port one of these 562mk2 yet to see how well they gain? Was considering buying one for my Dad and getting it ported up for him if they make worthwhile improvements
crosscut
OPE Member
9:23 AM
Alaska
I've done a few of them. They turn out great.
How's mine coming along ?
crosscut
OPE Member
9:23 AM
Alaska
That will be number 27 and done...... well until, well maybe , maybe not...
ZERO
Simple Life
7:23 PM
Woods & Mountains
Dan I take it no more vapor lock and such as we saw on the MK1 version. Your climate puts you right there with a large portion of the US.
On a job site, time is money, and fussing around with restarts is a big no no for a business owner.
AlfA01
8:23 PM
Evia, Greece
Exactly Mike. That was the only complaint I had about my old 562 was if it sat in the sun during summer months, you might as well grab another saw. It would restart any other time except for summer. Especially when you are paying a crane by the hour, saw problems just aren’t something you need.
Loggernate
11:23 AM
Idaho
Been pretty happy with mine
IMG_1972.jpegThe run on choke is nice, usually one pull starts cold. Only been is high 60’s but no heat / start issues so far. Both of mine are ported but mark 2 does seem to be little stronger than mark 1, smoother, revs fast. I do wish they would make air filter little bigger, holds them back, ported anyway. Installed red beard foam filter on old one, very noticeable difference, higher rpm in the cut, and also eliminated all hot start, run issues, I’m assuming because of the big hole in the top cover.IMG_1948.jpeg
Joe Kidd
I reckon so
1:23 PM
NC
Run on choke is sure different. I'm assuming it'll run like that for a warm-up before you blip the throttle? V3 version?
So the 550xp mkII had V2 & V3 autotune? My 2022 550 doesn't run on choke.
ZERO
Simple Life
7:23 PM
Woods & Mountains
550 mk2 2019 by @Stump Shot Steve
540 mk2 2022 by @Crocky28 Mark
will both run on choke till you pull on the trigger.
550 mk1 by AWOL
562 mk1 by @Mastermind will blubber and stall out just as any other saw on choke.
There sure have been advances in AT, generally your homeowner who may miss the very short blubber and flood the saw.
Joe Kidd
I reckon so
1:23 PM
NC
That’s odd. My 550mkII won’t run on choke. It’ll just pop like the old mk1’s did.
Tomos770
7:23 PM
Slovenija
My 550mk2 I think is 2022 runs with choke on ON wp....
