Husqvarna 435 Intake Leak
Huskyvarnya Saws
3:53 PM
Alabama
I have a Husky 435 that is on the verge of driving me nuts. First it was a transfer cover leak, so I disassembled the saw and fixed that. Then I found a leak between the carb and intake that was causing some erratic running. So I ordered a new inlet pipe and insulation wall assembly thinking that would surely do the trick. Well today I installed those and nothing changed. The saw still dies almost instantly when I spray carb leaner around where the carb and inlet pipe connect. Has anyone else encountered this issue before?
P.S. The 3 carb screws are good and tight just in case anyone is wondering lol
FergusonTO35
4:53 PM
Boonesborough, KY
I would try a coat of Permatex no. 2 sealant at every place where those parts join together. Sometimes they just need a little help!
kneedeepinsaws
2:53 PM
Oil Country
You know this is a fairly common problem with husky’s, I’ve always found that certain carbs have loose throttle shafts cause when you spray them directly the saw will die.
And there is no fix!!! So that’s why you’r probably pulling your hair out.
Thing is the saw runs good, but will fail the carb cleaner spray test every time when directed at the boot/carb. I went as far to make cork gaskets between the carb and boot thinking that seal was bad. But in the end it was the throttle shaft.
kneedeepinsaws
2:53 PM
Oil Country
Thanks, will remember that!
Spray the shaft directly with the red straw attached to confirm of course.
There is a thread about crappy tuning carbs in which the throttle shaft is mentioned as being loose being a problem. Making sure the butterfly is actually centred properly can help it seal properly. Other than that people have mentioned a new carb…
300DMMAG
4:53 PM
Maine
Please let us know. I have one and have not experienced anything problems.
