- 4:30 PM
- Dec 28, 2015
- Central Ohio
last tank met with a bad fate, help a
champion out
hmmm i will look at the tank i have, there isnt much stock in that area so I would like it to swap over with a minimum of changes
I was thinking the tank had the carb box. Been working on too many stihls.Throttle cable is different between the 394 and 395 correct? I thought the tanks were the same. The carb box floor sits on top of the cases, and the tank is below the cases...
Jacob i got a 395 tank im going to send to dave will it work ?
it is running an 8 pin right now, i will test 7 and 9 to see if it is faster eventually@Definitive Dave what are you running for a sprocket?
