Husqvarna 372 versus Husqvarna 372XPW versus Dolmar 7300
rb924119
Active OPE Member
9:15 AM
Pennsylvania
Hi, folks,
I’m new here and only joined about a week ago. I didn’t expect to post much, but I have a question and would appreciate all of your insight :)
I have eyes on a pretty clean bone stock Dolmar 7300. I’ve never run one, nor know of anybody who has. However, I have and have run the following saws, and would like to know how the Dolmar 7300 compares, mainly with respect to speed and torque:
-bone stock Husqvarna 372 XPW (75cc)
-mildly ported Husqvarna 372 XPW (75cc), ported with an emphasis on torque as opposed to chain speed
-Master Mind 372XP
Additionally, are they reliable?
Side note, I also have eyes on a pretty clean bone stock Jonsered 820 as well from a different seller. I understand that’s a different cc class, but any info on that would be appreciated as well.
I’m a big firewood cutter in the hardwoods of Pennsylvania, and I love torquey saws with generally broader powerbands as opposed to peaky powerbands in the high-RPM range. All of the above saws wear 24” bars, and my intention for the Dolmar and/or Jonsered would also be 24”.
Thank you all so much for your time and information!
-Ray
singinwoodwackr
7:15 AM
moon
Hi, folks,
-Master Mind 372XP
-Ray
looks like the 820 is similar to the Husky 281
rb924119
Active OPE Member
9:15 AM
Pennsylvania
Nothing bad with Dolmar but parts availability. If you are looking new i would sure look at the 572.
Yeah, the parts issue is sadly going to get us all one day with these older saws 😕 but I’ve been doing more research and it seems that Dolmar/Makita are further down that road than the other big names, so that’s definitely something to consider. It’s also why I’m trying to gradually build my lineup to be representative of which saws I love running but also which ones I use the most, so that I can rotate them and reduce the overall hours on any one saw. In theory, that should help me to alleviate some of the parts availability issues. Maybe. Hopefully. Haha
I’ve never had an opportunity to run any 5-series yet, but from what I understand, the 572 is kind of peaky with its powerband, right? Makes its power at the high RPMs with relatively less bottom-end power than its predecessors?
SOS Ridgerider
Muffler Modded Member
9:15 AM
Central CT
Ok, that’s definitely good to know. And I imagine the 7300 ported would be a little bit better than the ported 372, right?
I have a Dolmar 7310 that Kevin @huskihl ported. It’s my go to saw for firewood, and runs absolutely great. It’ll run a 24” bar with .404 chain without a problem.
Kevin is a great guy, and can really make the Dolmars run. He’s on a very short list of porters I trust 100%.
Whether it will run better than a ported 372 I can’t comment on, as it’s been so long since I’ve ran a 372 back to back with a 7300. Kevin will know.
9:15 AM
No I don’t believe that to be true. The 572 is the one saw in the 5 series that has a relatively wide power band and does well being dogged in. 550, 562 and 592 are all a little bit higher strung and peaky
sawfun
6:15 AM
Portland Oregon
I was not impressed by stock 372's, however ported,they are probably my favorite larger saw. I have had a stock 7900, and it was impressive for a stock saw. I have a Masterminded 372 xpw that is incredible, It's the saw I generally grab besides my Echo 2511t.
Hulsty
11:15 PM
Is it a working saw or a hobby? links to, what parts would you realistically need? I have Dolmars between 10-35 years old for a hobby and not issues getting parts. Look up the P/N, buy online done.
My 2c on the saws, 7300, light, powerful and easy upgrade to the 7900.
ZERO
Simple Life
3:15 PM
Woods & Mountains
372OE with the updated crank and build in Sweeden ported by @Stump Shot with a proper square setup is an absolute beast.
Can't make comparison to anything else, she is my most powerful in the fleet.
Finding large enough and bone dry wood to put her through her paces is my biggest problem.
Member
8:15 AM
Thanks for the kind words, Mike and Mike.
Hi, folks,
-Master Mind 372XP
-Ray
Hello Ray,
Great thing about the 372XP's is, they're still completely serviceable with them still in production worldwide. The Dolmar and Jonsered saw's mentioned were good tough saws, however, as mentioned, finding parts for service will require an owner that's patient and doesn't mind searching for parts when the time comes. Good news is, there is stuff still out there in the either to be had yet, and with the help of our friends here on OPE and elsewhere, one can usually get pointed in the right direction for what is needed. So, I guess it all comes down to personality, whether that older saw is a good fit or not for each individual. Also, it will help if that out of production saw you have is not depended upon as your sole source for your cutting. It's best to have backups to your backups at times.
Whatever you decide, if you have fun and enjoy what you're doing, that's all that matters.
Good luck
Steve
