husqvarna 359/7 build
1:09 PM
I wonder if the minimal gains are due to the fact that the RWJ is designed to run with the strato divider in the carb. I removed the divider in my 372XT carb and have been considering putting it back in to see what it does.
Could be. The idle wasn't perfect on the 390. I put a walbro 118 back on and it was fine. They work fine on the 7900 without it though.
SawTroll
Information collector
7:09 PM
Troms, North Norway
As I understand it the devider for the RWJ on the 372XT is in the intake, and not in the carb - so it shouldn't affect how the carb works on other models?
SawTroll
7:09 PM
Troms, North Norway
Divider is in between the butterflies as well. I've got 4 of them here without the divider
OK, that's what I originally thought - but some apparently inaccurate info had convinced me otherwise later.
This has been discussed a few times, without that devider ever being mentioned (that I can recall) - so I am quite surprised by this info.
Sty57
12:09 PM
Land of Cheese & Beer
They come with a divider. If you gut the intake you can feed the stratos with fuel.
Mike do you take the divider out them all?
I have one on my OE 372 with the divider still in it.
I have friend that put one on a 390 and left it in also.
Is there anything to gain with them out?
1:09 PM
Nope. Leave it in. They idle better with it in and gain pretty well nothing with it out.
1:09 PM
They idle fine on most of the 70cc saws I've put them on. It's weird it didn't idle right on the 390. It was a brand new carb at that.
XP_Slinger
They’re Just Saws
1:09 PM
Central NY
My brother XP_Slinger has the divider removed in the elbow and carb on his ported 372XT. It runs very well, even idles stable. Last I knew he was thinking about putting the divider back into the carb and see what if any difference it makes.
@XP_Slinger
Already brought that up Joe...page 3. I think it's time to finally put the divider back in
XP_Slinger
They’re Just Saws
1:09 PM
Central NY
Yup...the 372XT has a complete division of airflow for the strato ports. Air filter elbow, carb, intake boot and cylinder intake.
