Husqvarna 357xp hybrid build
smokey7
12:23 AM
Detroit
I am wondering what the stroke difference is if any and if the base bolt pattern is the same or close enough to make it work. Should be fun
sunfish
11:23 PM
Success Mo
Stroke and base bolt pattern are different enough to make this interesting & difficult.
Pretty sure it has been done before though.
Chainsaw Jim
Con Artist LLC
9:23 PM
Springfield Oregon
The stroke is actually the same and the bolt pattern overlaps each hole enough to make it without a drastic modification. The transfers will not be a problem as the 272 cylinder overlaps the case openings with plenty of room to spare.
I'll find out when I bolt the cylinder down but so far the squish is even looking like it will end up perfect without milling.
To me this is no more difficult than a 440/460 hybrid build....so far.
I'll figure something out with the mounting boss for the handlebar.
Chainsaw Jim
Con Artist LLC
9:23 PM
Springfield Oregon
I'm not sure which carb I'm going to use yet, so I'm not sure what I'm going to need to do. I may hog it out and epoxy the outside of the port to a round shape to strap a rubber boot around it. Or just go with the original intake block which I think would be the better idea.
sunfish
11:23 PM
Success Mo
Well, this is cool. I just assumed the stroke was diff. Very interested now!
Stihlbro
12:23 AM
Virginia
I would consider the Tillotson hs from either same saw, or as long as it has the low idle adjustment. You have plenty of options and I think either could work. Certainly gonna take some work, and as I'm typing this I believe this cylinder swap has been done before, I just can't remember when but believe it was from the Nova Scotia area.
Chainsaw Jim
Con Artist LLC
9:23 PM
Springfield Oregon
I would really like to see what that saw was like. I would never imagine I'm the first to do this. And it sure does suck that I can't find another example to drool over. Lol
Welder56
1:23 AM
Nova Scotia
@Basher was this you??
