Husqvarna 350 crank bearings and seals
JT78
1:18 PM
Burlington, nc
Need a good recommendation for bearings and seals on a 350. I put cheap Chinese crap in and only got about 10 tanks of gas before the seals were leaking. I want to buy a quality set can someone point me in the right direction?
Mattyo
Youtube speciawist
1:18 PM
Farmington, CT
Buy oem bearings and seals. Are you sure they are leaking from the seal around the crank or around the bottom plate?
Agent Smith
Hack of all trades
1:18 PM
Northeast ohio
Watch aftermarket seals on these as the seals center the crank where it needs to be and keeps it from walking. I tried aftermarket ones last winter on a build and they were narrower than the oem which allowed the crank to walk and journal/ case contact was made. Definitely do yourself a favor and go oem in this area
Mattyo
Youtube speciawist
1:18 PM
Farmington, CT
I can sometimes find good deals on ebay for the seal / bearing combos. Oem seals come already installed on the bearing. The install tool is helpful too to avoid puckering the seal.
Kiwioilboiler
346 Pic Examiner
5:18 AM
Marsden Pt, NZ
Also the factory 'relieved' the case a little on the retainer cap and case as the model development went on, I reckon to give the squished out bit of seal somewhere to go rather than pinching between the case and cap. I added a case relief with a handfile to my yr2000 case.
But I'm rough.
Finnrpm
8:18 PM
Finland
Do oem bearings still have a plastic gage?
