kårekloak
Preview
Have a husqy 345 which is converted with brand new 346xp top end and spacer from 350. The saw runs fine at idle and full rpm, but is bogging at mid rpm (and throttle at mid position) . I have replaced crank seals/bearings and tried several carbs. When I mounted the spacer, I hogged the impulse passage in the spacer so the 346 jug could fit, could I have done this wrong? Any suggestions?
I've tried attatched a video but get error (extension) after uploading
