Benwa
I love the smell of premix in the morning
So I have a 1997 3120XP that has the older style black coil. I'm looking to install a 272 unlimited coil. I have not yet, but will, run the 3120 in current configuration to check on where ignition timing is set at before tdc stock. I have no problem reclocking or rebroaching the early style flywheel to work with the 272 coil.
My question is for those that have done this with the older flywheel. Do you know how many degrees you need to advance the 3120 flywheel to match the 272 coil? I've searched, but haven't found the pertinent info.
If not, I'll sit down and do some comparing, figuring, etc. If I had a whole 272xp saw on hand as reference, I wouldn't even be asking. At any rate, I figured I'd save myself some time if somebody already had the info on hand. If not, I'll figure it out. Thanks in advance for any info.
