Husqvarna 3120xp ignition timing for unlimited 272xp coil
Benwa
I love the smell of premix in the morning
2:42 PM
Bow
So I have a 1997 3120XP that has the older style black coil. I'm looking to install a 272 unlimited coil. I have not yet, but will, run the 3120 in current configuration to check on where ignition timing is set at before tdc stock. I have no problem reclocking or rebroaching the early style flywheel to work with the 272 coil.
My question is for those that have done this with the older flywheel. Do you know how many degrees you need to advance the 3120 flywheel to match the 272 coil? I've searched, but haven't found the pertinent info.
If not, I'll sit down and do some comparing, figuring, etc. If I had a whole 272xp saw on hand as reference, I wouldn't even be asking. At any rate, I figured I'd save myself some time if somebody already had the info on hand. If not, I'll figure it out. Thanks in advance for any info.
Canadian farm boy
“Normal” people scare me.
5:42 PM
Ontario, Canada
About this much. Lol.
Idk the exact number of degrees.
I put a line straight between the center of the starter pawl bolts. Where the line crosses the crank bore in the FW is where you make the new keyway. You can fine tune it by filing the key.
I can’t take all the credit for figuring this out. I had some guidance from a few other guys that had done this previously.11EFF99A-0B03-4E7D-9EE5-1EA6F9C351A0.jpeg
Benwa
2:42 PM
Bow
I can’t take all the credit for figuring this out. I had some guidance from a few other guys that had done this previously.View attachment 315670
Thank you for taking the time! This is EXACTLY what I'm after. I was just after a baseline. I can run it with a timing light to fine tune it. Thanks so much. Major time saver! Always amazes me, stuff like this........... it's like it was meant to be. It SHOULDN'T be that simple....... but IT IS!
Moparmyway
Its just a saw
5:42 PM
In a meeting
Not too sure about anyone else, but my black coil equipped 3120 needed re-indexxing. My new green coil 3120 did not
I switched both to the unlimited coil
Unlimited coil wire screw
Old style coil wire screw
Unlimited coil on left, original coil on right
Old style flywheel on top, new style on bottom. Flywheel slots are lined up to show the difference in magnet placement
Old style coil, new limited coil (green) then unlimited coil
**EDITED to correct the information **
Thanks Kev !!!
Woodslasher
Teh debil
2:42 PM
Commiefornia
I read where some guy cut the third "leg" off a limited coil and it will "unlimit" it, but I haven't actually tried it so I don't know if it's true.
5:42 PM
Not too sure about anyone else, but my black coil equipped 3120 didnt need re-indexxing. My new green coil 3120 did
You had the wrong coil or fw on it to start then. The 272 coil times exactly like the green coil. I did have one that came in with mismatched parts. It would run alright, but it was popping pretty good in the cut
Moparmyway
Its just a saw
5:42 PM
In a meeting
I had a little more time to look at the pictures…..
I’ve got it backasswards ……..
The old one runs no keyway so it’s re-indexxed.9880C1BB-3046-4433-8C5E-807B71381E8B.jpeg
The new one was a direct swap
Sorry for the confusion men !!
Racer
10:42 PM
Earth
Hey guys, idu why my saw now refuses to start. I do 2 photos when my piston is in position TDC + position FW now.
Ignition 272. Stock FW and Ignition - OLD edition husqy with ~12k limited.
I made a new key FW as the guys showed above but saw stopped responding. It just floods the carburetor.
Spark ngk works well - i checked.
With stock timing FW and stock black coil - work well.
It turns out I set the wrong timing?
