Husqvarna 288 popping at WOT
smcrow
7:25 AM
Washington
Recently i got a Husky 288xp from my uncle. when in the cut with a 32" bar it pulls fine and cuts like crazy but i get a loud popping noise at WOT in the cut. was wondering if its 4 stroking, or if i'm having another issue i should be concerned about? if i need to get a video i will
10:25 AM
Was the timing ever advanced? And how much if so? I assume you know how to tune a saw looking at all the nice saws you have in your signature.
smcrow
7:25 AM
Washington
i do not know if its been advanced. i got it from my uncle who was a logger, who got it from my granddad who was a logger, who bought it off a logger he meet while steal head fishing in eastern Oregon. lol i have yet to tear into it all I've done is tune it is vac test, compression test and tune it. i'll have to get a video and upload
smcrow
7:25 AM
Washington
Key could be sheared..partially at least?? Coil could be on its way out also. Just some stuff to think about.
sounds like i'll be tearing into this one here very soon. i always forget about the possobility of sheared keys. it wouldn't surprise me on this saw either, it has about 180 psi compression
smcrow
7:25 AM
Washington
Don't forget some of these carbs have the governor built into them, easy to defeat but the do sound different when hitting the governor
interesting, i did not know that, how does one know if the carb has the governor in it? and how does one defeat it?
10:25 AM
There’s another carb other than the common “governed”’one that has an auxiliary jet inside carb in the metering well. Same basic principle, but it’s internal rather than external. I couldn’t get mine to keep from 4 stroking on and off in the wood. I soldered the main jet closed with intentions of drilling it smaller. Tried it without drilling the jet and it tuned at around 1 turn out so I left it. Probably not pertinent here, but just mentioning it for future readers
XP_Slinger
They’re Just Saws
10:25 AM
Central NY
Lots of good advice in here. Put me in the ignition club, partially sheared key or poor connection on the blue trigger coil. I’ve experienced both and it popped like crazy. Didn’t resemble 4 stroking at all
Disciple of Monkey's
9:25 AM
Ignitions are pretty tough on these saws, doesn't mean they can't go out. A bad ground with the coil in the carb box could be all this is. Can be found out with an ohm meter or just clean and tighten the grounding screw and run it.
