Husqvarna 288 394 flywheel part # mystery solved
Mattyo
Youtube speciawist
1:13 PM
Farmington, CT
yup, thats a 394 flywheel, but they key definitely does not match up with the 288 flywheel... again, if I get the chance later I'll post pix
okielumberjack
12:13 PM
Gods country
Man now im gonna have oc and have to go to my buds and pull the 394 back down and invetigate:sherlock:i used the fmrtc 288 fy, i swore i double chkd the keyway in relation to the magnets. The saw runs perfect, i noodled some big ugly oak firewood rounds,to load it good for a test run
Mattyo
Youtube speciawist
1:13 PM
Farmington, CT
don't tear it down if it runs lol... i'll do the investigation from my end no worries :)
Mattyo
Youtube speciawist
1:13 PM
Farmington, CT
It appears the 288 flywheel has advanced timing compared to the 394. 394s do run with considerable advance so it would make sense that a 288 flywheel would fit. However ....a 394 flywheel might make the 288 timing too retarded. ..who knows.
If anyone has better info let me know. Visually it's about 1/2" difference around the circumference. ..
circumference is 14.7" or so.... divide that by 360. Roughly 40 thousands is 1 degree. So ... it's about 12 degrees advanced
Rough numbers
Basher
2:13 PM
Canada
That sounds about right, its been 13 years since I modified 394`s, did some stuff with them around that time but kept no records back then. Blew one up right in my hands, oopsie!
okielumberjack
12:13 PM
Gods country
That makes sense why the the 394 i put the 288 fy on runs good. I bet your right going the other way around
