Husqvarna 268...
smokey7
12:57 PM
Detroit
No e job. I'd buy the 368 stuff if price is right.
Good job.
Motorhead
Cantre Member
12:57 PM
Tampa Fla.
I have a 61 husqvarna that I changed over to an aftermarket 272 piston and cylinder, Bolted right up, The 272 top end is the way to go.
bplust
12:57 PM
Wheelock
4mm carb bolts is what I have
Depending on the cylinder you get, you might have to get larger bolts and drill out or get another block. The other option is to use the small bolts in the larger cylinder holes. I've had good luck wrapping a rubber band around the muffler, cylinder, and the air filter mount, holding everything tightly together and preventing an air leak at the carb. You have to put a new rubber band on every few cuts, as there is an issue with melting, but it does work ok.
Motorhead
Cantre Member
12:57 PM
Tampa Fla.
Huh?
Adirondackstihl
12:57 PM
Upstate NY
I have yet to have an issue smearing some anaerobic on a used one (I'm serious about this post).
This one looks in good shape.
I'll put some Yamabond around the OD.
Looks to me like the oiler needs to be mounted when installing the PTO bearing?
