Husqvarna 2100 thread
Jusgunn3
1:43 AM
California
If you do get replacements, make sure if yours has coarse threads or fine threads. Not sure if the 2100s have the same issue, but I had a 272 that I bought the coarse threaded AV mounts for and it required fine threads - of course the harder and more expensive ones to find.
Very good to know, thanks!
Woodwackr
2:43 AM
ID
I noticed that the saw is a little wobbly and my hand on the bar would touch the top cover when it would dig in. I assume I need to replace the AV mounts, are the AM ones good enough?
26 97-02 soft
26 97-04 hard
Fine thread
Looks like there is only 1 size.
Plenty of am out there
Jusgunn3
1:43 AM
California
Do you have the tool for them? I don't and have been using needle nose pliers and have boogered up a few doing it. I need to get the AV tool or make one!
I do not have a tool either.
If these don't work out, I've got some off of parts saws that you can have.
Thank you for the offer, I will let you know.
Don’t bother with the cheap eBay ones…garbage. I wound up making my own
Got it, how did you make them?
Jusgunn3
1:43 AM
California
I can’t seem to find sets only one or two here or there…anyone have some NOS ones they want to sell? Or I go AM and change them out again down the road I guess.
hacskaroly
2100 Fanclub Member
1:43 AM
Northern Idaho, Ehh
I ended up getting mine on ebay if i remember correctly.
hacskaroly
2100 Fanclub Member
1:43 AM
Northern Idaho, Ehh
If you look close at the end of the tool (rounded end) there are two nubs on the end, I think it also fits down and around the AV mount and those two nubs fit in the metal slot of the AV mount allowing you to turn it. I don't have one, I just assumed that is how it worked from looking at it.
Woodwackr
2:43 AM
ID
Ah, couldn’t see that.
