JacobSaws
Active OPE Member
I'm about done with my Husqvarna 141 build. I bought as a parts saw, cleaned it all up, and replaced many parts. I go to run it for the first time and doesn't want to start, idle screw does nothing, runs like crap, and doesn't want to restart. I suspect it has an air leak, so I tear it all down to do a pressure test and both seals are just flowing out air from the inner lip. I end up rebuilding this damn clam shell 3 times because it never wants to hold air. It has new oem bearings and seals, crank has been inspected and polished, and it's super straight forward to install the bearings and seals. But I must've done something right after trying different ways of installing the seals because now the flywheel side doesn't leak and clutch side very little, like it will hold 5 psi for about a minute. I tried 7 psi and it would stay for longer. Is it ok for a very little to leak? Or should there be no leak at all? Currently this saw is in pieces, and I'd like to get it all together but not if it's going to run bad. Please lmk what you guys think
