Husky intake block repair attempt
davidwyby
Rural desert logging
1:02 PM
Extreme Southeast CA
Block from a parts saw got a little melty. Think it will seal without the raised sealing ridges after I resurfaced it? Or will it need some help from Mr. MotoSeal? D0F6A3AB-2B2E-439C-96CF-D746D522A6AF.jpegEABD32C6-2BC8-4135-8F87-A2F2D66A9C6E.jpeg663DE2FF-0C4A-4AC1-AB1F-A449B1F1E8AF.jpeg
4:02 PM
Loctite 518 doesn’t work great in plastic to metal sealing applications. Only metal on metal. Just my experiences with the husky 350 plastic riser to metal case sealing surface. Dunno if this would be any different.
Steve
Excellence!
3:02 PM
It works well as a dressing for a gasket in this instance. But you are 100% correct on the metal to plastic thing. I never tried it on the block adaptor on a 350... :oops: (I have and it failed too!)
CJ Brown
4:02 PM
Belleville, Ontario, Canada
I've had good luck with Permatex Spray-a-Gasket. It goes on thin and evenly and tacks up nicely after a few minutes. It doesn't harden either so separating parts at a later time is not an issue.
Sawrain
6:02 AM
South.
I did the same with a 262, surfaced it and used a dry gasket.
It has been fine, but hasn’t done much work admittedly.
