Mooselegs
OPE Member
- 9:42 PM
- Mar 4, 2024
- Langley, B.C.
I have a 1991 Husqvarna 55 Model Chainsaw which I am Rebuilding and was Leaking Oil Profusely from the Pump. I have taken the Pump Apart and Noticed that the Groove Pin Part # 721 12 10 40 was Missing which shows as being 3 x 20 which i am assuming is 3mm Dia.x 20mm OAL. Can i Just Replace this with a Split Roll Pin and can some tell me if this is Just a Locater pin or does it go through the small hole in the Pump and Plunger. Also what grease is used in Pump Plastic Body
