Brewz
- 12:29 AM
- Jan 16, 2016
- Hunter Valley - Australia
Hi Folks.
I am a Stihl boy but am keeping a really nice 2010 372xp I picked up in a pile of dead loggers saws for $30 each.
All that was wrong was the 2 front screws came loose on the cylinder and the cylinder lost its seal.
The previous owner said he didn't have it long and it just stopped one day, and in the shed it had sat since.
Stripped, cleaned and reassembled in one afternoon and it runs perfectly.
It just needs a new muffler, with more openings!
Now, for my questions.
Firstly I am assuming it is an EPA model as it has limiters on the carb screws and a 2 ring piston. It also has a blue coil when all the other older saws I have seen in this series have black coils.
In the pile of parts that came in a box with all the saws there was an older pre EPA 372 and a 371 which had been stripped of parts to keep other saws running.
I have gathered up enough bits and ordered others to get the parts 372 running but I am left with some 371 bits, including a very nice OEM cylinder, carb, black coil etc.
Considering I want performance from the saw..........
1. Is the blue coil a limited coil and would I be better off with one of the older black coils?
2. Without timing the 371 and EPA 372 jugs (which I will do), is one of them preferable by those in the know?
3. should I keep the limited carb on it with the limiters removed or should I use the older 371 carb?
If it was a Stihl I would likely keep the newer Cylinder, buy a single ring 371 meteor piston for it and fit the older carb and coil, but I dont know husky's so well yet.
Should be a fun little saw to get running nice.
