Husky 350 wont lean out?
JT78
7:33 AM
Burlington, nc
Ok so I have a Husky 350 that's been rebuilt and ported I cut the base and took .010 out of the squish band and raised the exhaust back up .010 widened intake and exhaust saw runs great but won't lean out with H screw all the way in its still only turning 13,300. I tried adjusting the diaphragm needle lever and no luck? Thinking about trying a different carb this one is an older 350 with walbro any info would be great. Also any ideas on why it won't lean out?
JT78
7:33 AM
Burlington, nc
Good question I didn't think they put limited coils on the older 350's ?
JT78
7:33 AM
Burlington, nc
So did some more searching and reading zama 42 is supposed to fit? any mods needed to make it work?
7:33 AM
Bet it's the carb, if it isn't anything suggested earlier in thread.
JT78
7:33 AM
Burlington, nc
Muffler doesn't have a screen just a big hole now. checked the coil which one is the limited one this one is black.
Motorhead
Cantre Member
7:33 AM
Tampa Fla.
I ported a husqvarna 51 one time and couldn't get it to go past 13000 it had a kolbinschmit cylinder,I switched over to a mahl. because I noticed the mahl cylinder had wider transfer ports.When I got it all back together the saw with the ported mahl cylinder turns 14500,
JT78
7:33 AM
Burlington, nc
This one has the original husqvarna cylinder assuming it's Mahle ports were widened to 29 mm
old guy
Love me some Husqvarna
6:33 AM
Becker Minnesota
Black coil is unlimited. I had two 45cc 346s act like that, a carb kit cured them both. Do you have the open port 44 cc or the closed port 45 cc?
Fishnuts2
6:33 AM
SE MN
I got an extra 700 RPM out of my 350 by going from a "cleaned" air filter to a new filter.
