rfarr94
OPE Member
- 1:36 AM
- May 15, 2021
- Powhatan va
Building a 61 to 272 and was wondering if should get the oem intake block or were the aftermarket ones from HL good quality
Just fyi, you can get $7 SKF 6202 C3 shielded bearings for those saws from ebay. I forked over $40 for two of those bearings at the husky shop and they showed up in the same little boxes as the $7 ebay ones. Just pop the shields out and you're good to go.Hopefully you guys don't mind if I jump in with a similar question.
Which parts do you use AM and which avoid? I'm rebuilding saws on same chassis and bought quality brgs at work, OEM husky seals and gaskets. I imagine AM gaskets would be OK but doubt crank seals. Could have saved a few $ with a Hyway gasket and seal kit.
Thanks
Some of these parts sellers know not what they sell. I see bad listing all the time for 1124 Stihl parts.I saw that on a website for the intake block. It said genuine oem 272 intake block then below it said also fits 61, 66, 266 which didn’t make sense to me.
I been running AM seal from Hyway for years in commercial work saws with no issues. Gaskets are hit and miss but Hyway was always good so far.I always go OEM for fuel lines and usually for crank seals. I do have a few saws of my own and with a close friend running Hyway seals for testing, 2 years so far with no issues.
My dealer stocks the fuel lines and seals, so it's also a matter of convenience.
I second unsheilding the shielded bearings, bonus is they are greased so they aren't dry on initial startup too.
Internally, yes.Got the parts for the 272 top end today. Bought what supposed to be a 272 intake block from HL and
What I got looks identical to the intake that was on the 61. are the 272 intakes noticeably different?
