Husky 181 Thin Ring end gap???
Brewz
4:38 AM
Hunter Valley - Australia
Hi Folks
I have just torn down a nice old Husky 181 and found it has a thin ring piston.
Cylinder bore and the piston are in fantastic condition but when I put the tings in the cylinder, there is a LOT of ring end gap.
I am wondering if anyone can tell me if this is normal or are the rings worn out?
There is a set of new rings on ebay but they will be about $140 AUD delivered to me in Australia.
Brewz
4:38 AM
Thanks mate
I will look into it
I recon it will go good with a bit of grinding work.
Any thoughts on advantages of the 181 piston with 100% transfer feed via the piston windows V's a single ring meteor that is more like a 394 piston?
I am wondering which one will feed the lowers better
2:38 PM
The 281 single ring is a direct fit if you want a new piston. Have put the piston at BDC and study.
David Young
Safety First !!!!!!
2:38 PM
vt
The other benefit is lower cranking compression / pressure. But when the gas is behind it. It will increase compression
Thin rings are different mr brewz
The rings don't have a radius to match the ring pin. They come in flat. I think you may get away with more end gap. You can also swap the bottom and top ring
David Young
Safety First !!!!!!
2:38 PM
vt
Also I have heard less ring flutter at high rpm. But I don't have real proof just reading that thin rings are better
griffonks
12:38 PM
Boulder, CO
I am thinking I will go this way and just order a new Meteor.
I might be able to find a set of rings for ya but personally I would use homelite rings. I got a set of 266 thin rings a couple mos ago for around $20.
But if you decide to use a 281 thick ring slug I got a nos oem slug kit that I'm not planning on using. I'd trade for the thin piston and some boot.....
Sent from my SM-T815 using Tapatalk
