How to square file
beaglebriar
The Peanut Gallery
1:59 AM
Warren Center, PA
It will take some messing with the angles, but you will get it to where you like it.
That's what I'm thinking. like it plenty for firewooding, just need to make some changes for felling.
Or stay with round for the woods. I can touch up a round chain in a couple minutes and be back to work.
p61 western
Ol Mudflap
10:59 PM
GFY
Could be just a couple of minor changes, and be good for both.
beaglebriar
The Peanut Gallery
1:59 AM
Warren Center, PA
Is it progressive like the Husky or fop?
This is what I normally grab when I use one. I have the husky type also.
Skeans1
10:59 PM
Should be the other way around, a round chain should be on the landing/firewood chain.
Falling is a great place for running square, normally first thing in the morning my chain will be grabby but I’ll smooth out through the cut.
This is one of my chain in a second growth Doug fir on a property line, same chain cut some alder as well.
beaglebriar
The Peanut Gallery
1:59 AM
Warren Center, PA
Go to 0.030 or 0.035
If you could see how the angle changes as 0.025 remains constant as the tooth gets filed back to the end of its life, you would switch to the progressive guide or switch to nailing 5-7 degrees
I'll give it a try. Thanks
beaglebriar
The Peanut Gallery
1:59 AM
Warren Center, PA
Doug fir and alder are quite a bit different than what we have here. Various Oak Maple and hickory mostly. Not that your chain wouldn't work.
Skeans1
10:59 PM
We have oak and maple out here as well. Doug fir is a fairly hard wood as well it’s not far behind some oaks, it’s not a true fir or like a Hemlock or spruce conifer.
1:59 AM
OK
You were asking for angles and stuff. So you just guesstimate your file angles. [emoji106]
