How to square file
3:33 PM
Ahhh. Makes sense then. Thank you sir.
I just wanted to check to make sure I wasn't doing anything differently. As in wrong. Lol
Duane(Pa)
It's the chain...
3:33 PM
Centre County
Artisan wood workers study wood structure and composition. Each piece of a jewelry box might be hand selected for just the right alignment of grain in a fancy joint or on a surface. I guess the point is, that they study fiber cutting efficiency too.
Here again, I'm the dude that thinks a dead barkless tree is a work of art. That, and I shoot rabbits...
beaglebriar
The Peanut Gallery
3:33 PM
Warren Center, PA
WOODS
3:33 PM
UETN
@brshephard
While in the garage today, I remembered you asking for pics of the double bevel file adapter barrels I turned on the lathe for the newer style file n joint or Oregon guide. Here they are
View attachment 138872 View attachment 138873 View attachment 138874
That is what I need; the bushings not a lathe. I ground down some aluminum cable stops with a drill and the belt grinder, then drilled and tapped a set screw hole. Worked only fair due to file length. Tonight I thought I had the left cutter angles worked out so I rotated the file for the right cutter and one of the bushings fell off never to be seen again. Your larger bushings and the flat file look a lot easier to set the angle. Maybe I can talk a local machinist into making some for me.
What files are you using?
Ron
3:33 PM
Ron
I use bahco from here
https://aboloxtools.com/bahco-4-150-07-3-0-flat-chisel-bitfile-7
Vallorbe seem to be better, but difficult to find
3:33 PM
Ron
You can also get an older granberg 106 (I think that's the model) or an older Oregon with the triangular shaped file holder. It's already at a decent angle for a double bevel file. No bushings required
concretegrazer
2:33 PM
Mo
Ron
I missed that you were using a 3 corner file. My #'s were with a double bevel like Kevin linked above. & I think I had the chain stop fully extended as well.
WOODS
3:33 PM
UETN
I have read that the 107 was made for square filing, but finding one is tough. I have a 108 and it is basically triangular but it doesn’t hold the small triangular file very well. Will the 6 sided flat files fit?
Ron
3:33 PM
Ron
If it's like the last pic I posted, yes. I had to grind about .010" off the width on both sides on the wide end of the double bevel file.
